Driver Configuration
This Driver does not use [P] configuration parameters. All IOKit library configurations, and the ones specific to this Driver, must be performed on this Driver's properties window or on the Extra Settings option in Elipse SCADA.
On this properties window, the RSSP_I_Server tab contains specific settings for this Driver. The other tabs refer to communication settings of Elipse Software's IOKit library.
For more information about the configuration of IOKit library, please check topic Documentation of I/O Interfaces.
