Driver's Revision History |
Version |
Date |
Author |
Comments |
1.0.4 |
09/28/2026 |
A. Fetzner |
•A request with any value from the template not yet written to a Block Tag for Sending is now refused, with the field registered on the log file. Previously that request was sent with an empty body or with the template keyword instead of the value (Case 40840). •Texts with accented characters are now correctly sent and received, with a request's body in UTF-8 format. Previously a value with an accent interrupted a writing and an accented value received from the API reached a Tag corrupted (Case 40839). •Writing to a Block Element beyond the last item of the linked template in JSON format now fails with a message in the log file of this Driver, instead of causing an invalid access (Case 40838). •A field declared as a list on a template for sending in JSON format, such as "field": ["E3VAL"], is now sent as a list. Previously the value erased the list and the field was sent as a single value (Case 40837). •Values received as text are now converted to numbers only when the whole text is a number. Texts such as IP addresses (192.168.17.30) are delivered as text (Case 40818). •Any HTTP response in the range 2XX (from 200 to 299) is now treated as a success in requests. Previously, only the 200 code was accepted (Case 40306). •Writing a whole Block Tag for Sending at once now distributes each Element to the parameter of its respective position, as already happened when writing Element by Element (Case 40201). •Added a new reading mode without a template using JSON Path Tags. The Item parameter of this Tag receives the path of a value in JSON format from the response with the $ (dollar sign) prefix, supporting nested keys, indexes, wildcard, date macros, and timestamp of data (Case 40406). |
1.0.3 |
12/22/2025 |
A. Fetzner |
•Fixed problems when parsing data in JSON format and in communication using the HTTPS protocol (Case 39116). |
1.0.1 |
10/28/2025 |
A. Fetzner |
•Initial version of this Driver. |
