subwall
subwall
Read-Only
Use a PLC Tag to write the execution parameters of the subwall command. This Tag is configured by the subwall.write Tag.
Syntactic parameters
Device
Not used and must not be filled
Item
subwall
If this command is successful communicating with a controller, the Value property of this Tag contains a text in JSON (Javascript Object Notation) format.
