setwindowtext
setwindowtext
Write-Only
Use a Block Tag to execute a setwindowtext command.
Syntactic parameters
Device
Not used and must not be filled
Item
setwindowtext
The parameters that can be written must be in the next sequence. Empty parameters are not considered and they must be understood as not sent.
SWNAME
LYTNAME
UID
WT_ENABLE
WT_TEXT
WT_X
WT_Y
WT_FCOLOR
WT_BCOLOR
WT_FSIZE
WT_FFAMILY
WT_BTN_VISIBLE
WT_BTN_COMMAND
WT_BTN_CAPTION
WT_BTN_SWNAME
WT_BTN_LYTNAME
WT_BTN_SRCNAME
WT_BTN_BLUR
