Properties
Properties
These properties control the configuration of an Ethernet Interface.
NOTE
The Ethernet Interface is also used by the RAS Interface.
The available properties on this section are the following:
IO.Ethernet.AcceptConnection
IO.Ethernet.BackupEnable
IO.Ethernet.BackupIP
IO.Ethernet.BackupLocalPort
IO.Ethernet.BackupLocalPortEnable
IO.Ethernet.BackupPort
IO.Ethernet.IPFilter
IO.Ethernet.ListenIP
IO.Ethernet.ListenPort
IO.Ethernet.MainIP
IO.Ethernet.MainLocalPort
IO.Ethernet.MainLocalPortEnable
IO.Ethernet.MainPort
IO.Ethernet.PingEnable
IO.Ethernet.PingTimeoutMs
IO.Ethernet.PingTries
IO.Ethernet.ShareListenPort
IO.Ethernet.SupressEcho
IO.Ethernet.Transport
IO.Ethernet.UseIPv6
