Driver Revision History
Version
Date
Author
Comments
3.0.14
11/05/2025
M. Ludwig
•Fixed a GPF (General Protection Failure) when executing a ping command (Case 39008).
3.0.13
09/02/2025
M. Ludwig
•Driver updated to IOKit library version 3.0 and Visual Studio 2022 (Case 37963).
3.0.12
09/18/2019
C. Mello
•Driver ported to Visual Studio 2017 (Case 27518).
3.0.11
05/11/2017
A. Hertzog
•Adjustments for compatibility with multiple instances (Case 17678).
3.0.9
10/29/2014
A. Quites
•Implemented a scan of ranges of IP addresses (Case 15917).
•Implemented an option to retry failed ping commands before returning a value of 0 (zero) (Case 17412).
•Driver ported to IOKit version 2.0 (Case 15977).
2.1.1
09/01/2011
A. Quites
•Created a compatibility mode to avoid problems with servers not accepting ping commands without data bytes (Case 12077).
•Fixed an error in which this Driver could return success for ping commands to non-existing servers when using high time-out values (Case 12064).
•Implemented a limit value of 100 to the maximum number of threads (Case 12445).
•Small performance optimizations.
2.0.1
04/24/2009
A. Quites
•Implemented the execution of ping commands in parallel in multiple threads (Case 10210).
•Driver ported to IOKit library.
1.0.1
R. Haetinger
•All publications before revision control.
