Driver Settings
Driver Settings
This Driver's [P] parameters for configuration are not used. All configurations are performed on the configuration window, shown on the next figure.
MProt tab
MProt tab
The available options for the General group are described on the next table.
Available options for the General group
Option
Description
Default Slave Address
This can be used as the default address for any Tag. Leave the N1 parameter in 0 (zero) so that it is replaced by the default address
Network
Protocol selection. Available options are PPI, MPI, ISOTCP, ISOTCP243, or IBHLinkMPI. The PPI, MPI, or ISOTCP/ISOTCP243 groups on this tab are enabled or disabled according to the selection of a protocol
Local Address
Address of this Driver on the network. It can be selected arbitrarily
The available options for the PPI group are described on the next table.
PPI group
PPI group
Available options for the PPI group
Option
Description
PPI Multi Master
Informs this Driver that there are other Masters on the network
Application Timeout (ms)
Maximum communication time for each Tag, in milliseconds. Available only when this Driver is a Multi-Master
Operation delay (ms)
Stop time for an interval between communication operations, in milliseconds. Select the only for write option to apply this interval only for writing operations. For more information, please check the next note
NOTE
The Operation delay (ms) option adds a minimum waiting time that must occur between the ending of a reading or writing operation and the beginning of the next one. Use a value different from 0 (zero) on this configuration only if facing communication failures caused by the processing inertia of a device. Writing operations are the most affected ones, because they are usually random, and for these operations there is the only for write option. If this option is not selected, the waiting time applies to reading and writing operations. If it is selected, it only applies to writing operations, which is recommended. Notice that adding a waiting time may slow down the performance of an application.
The available options for the MPI group are described on the next table.
MPI group
MPI group
Available options for the MPI group
Option
Description
Highest Station Address
Indicates the greatest available address on the network, so that in PPI and MPI modes this Driver discovers other possible Masters on the network. Only the 15, 31, or 63 values must be added
Profibus Speed
Nominal speed of a Profibus network
The available options for the ISOTCP / ISOTCP243 group are described on the next table.
Available options for the ISOTCP / ISOTCP243 group
Option
Description
Extra Connections
Number of additional TCP connections that can be created to improve communication performance
Max Simult Req
Maximum number of simultaneous variables on a single request. This configuration can be used to significantly improve communication performance, as long as users use a value greater than 0 (zero) in the Extra Connections option
Source TSAP (hex)
A number formed by a Word in hexadecimal identifying the local TSAP in the protocol
Connection type
Type of a connection. Possible values are PG, OP, or PC. It must be selected according to CPU configuration
Watchdog period (ms)
Interval in milliseconds for the expiration of Watchdog Tag. If this Tag exists and its value does not vary inside this interval, then this Driver performs a switch of IP address
Use Dest. TSAP
If this option is selected, enables typing values for Dest. TSAP. If this option is not selected, enables typing values for Rack, Slot and Connection type
Use default TSAPs
If this option is selected, uses default TSAP values and so disables typing configuration values of Source TSAP, Dest. TSAP, Connection Type, Rack, and Slot
Source Ref. (hex)
A number formed by a Word in hexadecimal identifying a source reference in the protocol. It is only enabled when the Use default Source Ref option is not selected
Rack
Destination CPU's rack number
Slot
Destination CPU's slot number
Dest. TSAP (hex)
A number formed by a Word in hexadecimal identifying the destination TSAP in the protocol
Backup 1 / Backup 2 / Backup 3
Enables typing rack and slot values for the respective backup CPU(s), for use in redundancy systems with values different from the main CPU
For this Driver's communication to work with Siemens S7-1200 device model, users must select the ISOTCP option, deselect the Use default TSAPs option, configure the Source TSAP (hex) property to "0100", and define the Connection type option as "PG", Rack with 0 (zero), and Slot with 1 (one).
NOTES
•When selecting the ISOTCP or ISOTCP243 protocols, all Tags in an I/O Driver object must have the N1 or B1 parameter configured in 0 (zero) and the Default Slave Address parameter also configured in 0 (zero).
•The Source Ref and Source TSAP parameters must be considered only in very specific cases. Due to successful executions in a wide range of topologies, it is strongly recommended to always keep the Use default Source Ref selected and the Source TSAP value always as "0100".
•When the Use Default TSAPs option is selected together with the ISOTCP protocol, the Source TSAP value is "0100" and the Dest. TSAP value is "0202".
•TSAP stands for Transport Service Access Point, which is a terminology used by the ISO protocol.
•When using PC - PPI/MPI serial adapters, it is very common the need to configure the handshaking on the Serial tab of the configuration window of this Driver. Only the RTS control must be configured to ON. If there is any unsuccessful communication during initial tests with this Driver, it is advisable to try that change, RTS Control configured to ON, and execute that test again.
