I/O Tags |
The Tags described next allow controlling and identifying an Ethernet Interface at run time and they are also valid when the RAS Interface is selected.
IMPORTANT |
These Tags are available ONLY while a Driver is in Online mode. |
The available Tags on this section are the following:
