Configuration Dialog Box |
The dialog box of I/O Interfaces allows configuring the I/O connection used by a Driver. This dialog box contains the Setup, Serial, Ethernet, Modem, and RAS tabs, described on the next topics. If a Driver does not implement a specific I/O connection, its corresponding tab is not available for configuration. Some Drivers may contain additional tabs, specific for that Driver, on the configuration dialog box.
