Configuration of a Driver |
I/O Interface configuration is performed on a Driver's configuration dialog box. To access the configuration of this dialog box in Elipse E3 in version 1.0, follow these steps:
1.Right-click a Driver object (IODriver).
2.Select the Properties item on the contextual menu.
3.Select the Driver tab.
4.Click Other parameters.
In Elipse E3 version 2.0 or later, click Configure driver
on a Driver's toolbar. In Elipse SCADA, follow these steps:
1.Open the Organizer.
2.Select a Driver on Organizer's tree.
3.Click Extras on the Driver tab.
Currently, an I/O Interface allows opening only one connection for each Driver. This means that, if users want to access two serial ports, they must add two Drivers to an application and then configure each one of these Drivers for each serial port.
