Tag Reference
Tag Reference
The Tags of this Driver allow direct access to objects provided by an MP85 module. This access can be performed using PLC or Block Tags, according to the object to access.
A full list of objects available for each module, as well as parameters for indexes, sub-indexes and sizes, can be checked on the module's operation manual.
The next topics contain the Tags supported by this Driver, in which the N1 or B1 parameter specifies the object to access and the N2 or B2 parameter specifies the sub-index of an object to access.
