Optimization Tips
Optimization Tips
This topic enumerates some optimization tips to communicate with Slave devices.
Tips for Configuring this Driver for Elipse E3, for Elipse Power, and for Elipse Water
•Use Superblocks whenever possible, preferring to create simple Tags, or PLC Tags in Elipse SCADA, instead of Block Tags. For more information, please check topic Superblock Reading (Grouping).
•If Superblocks are not an option, prefer to create Block Tags, grouping the largest possible number of variables in the smallest number of blocks. For more information, please check the text about manual grouping on topic Superblock Reading (Grouping).
•Consider all recommendations of article Performance tips for Elipse E3, on Elipse Knowledgebase.
•In case of high-latency networks, reduced bandwidth, or packet loss, please also read article Network Settings in Elipse E3 for networks with high latency, low bandwidth and/or packet loss.
•In high-latency networks, configure higher time-outs by considering the expected latency. Remember that a time-out is only effective on delays, not interfering with performance on normal usage situations. If time-out failures on a particular Slave device are very frequent, consider enabling the Auto-Demotion mode to temporarily remove that device from communication.
Tips for Configuring this Driver for Elipse SCADA
•Prefer creating Block Tags, by grouping the largest possible number of variables in the smallest number of blocks. For more information, please check the text about manual grouping on topic Superblock Reading (Grouping).
•Consider all recommendations of article Developing applications with optimum performances, also available on Elipse Knowledgebase.
Tips for Configuring or Programming a Device
•If possible, group all variables defined by a resident application, or ladder, that have the smallest scan time, in contiguous addresses in the memory of a device. The total scan time of Tags highly depends on the capacity of grouping variables in communication blocks.
