List of Default Exceptions of the Modbus Protocol |
The next table contains a list of default exceptions defined by the Modbus protocol specification, version 1.1b.
Exceptions are registered on this Driver's log, whenever detected, and they can be read by an application by reading the last exception code.
Notice that, in addition to the exceptions listed here, a device may define other proprietary exceptions. In this case, they are supposed to be described on manufacturer's documentation of that device.
Exception codes standardized by the Modbus protocol
Code (in Hexadecimal) |
Name |
Meaning |
01 |
ILLEGAL FUNCTION |
The received function code is not valid. This may indicate that this function is not implemented yet or a Slave is in an inadequate status to process it |
02 |
ILLEGAL DATA ADDRESS |
The received data address is not a valid address. More specifically, the combination of a reference address and the amount of data to transfer is invalid |
03 |
ILLEGAL DATA VALUE |
The current value in the request of a Master is not valid. This indicates a failure on the remaining data structure of a complex request, such as when the informed size for a data block is not correct. This exception does not indicate that values submitted for writing are out of the expected scope by an application, as such information is not accessible to this protocol |
04 |
SLAVE DEVICE FAILURE |
An irrecoverable error occurred during the processing of the requested function |
05 |
ACKNOWLEDGE |
Used with programming commands. A Slave accepted this message and it is processing it, but this processing demands a long time. This exception prevents a time-out in a Master. The end of this request must be tested by a polling process |
06 |
SLAVE DEVICE BUSY |
Used with programming commands. Indicates that a Slave is processing another long-lasting command and that this request must be sent again later, when this Slave is available again |
08 |
MEMORY PARITY ERROR |
Used with functions 20 and 21, reference type 6 (six), to indicate that the extended file area failed on a consistency test. A Slave device may need maintenance |
0A |
GATEWAY PATH UNAVAILABLE |
Used together with gateways to indicate that a gateway was unable to allocate an internal path to process this request. It usually indicates that a gateway is not correctly configured or it is overloaded |
0B |
GATEWAY TARGET DEVICE FAILED TO RESPOND |
Used together with gateways to indicate that no response was received from a destination device. It usually indicates that such device is not available on the network |
