Driver Settings
Driver Settings
All configurations are performed on this Driver's properties window. When adding this Driver to an application, it is loaded with its default configuration of extra parameters for an Ethernet interface, that is, TCP/IP port 5001 and time-out of 1000 milliseconds. Users must open this Driver's properties window and configure a valid main IP address referring to a device to access. For more information about Setup and Ethernet tabs, please check topic Documentation of I/O Interfaces.
The MitsubishiMC tab contains only the Standard maximum string length option, which corresponds to the maximum standard size of a String-type variable. The default value of this option is 128 and this value can range between 1 (one) and 128.
