Driver's Revision History
Version
Date
Author
Comments
4.0.1
02/13/2026
M. Ludwig
•Driver updated to IOKit library version 3.0 and Visual Studio 2022 (Case 38173).
3.3.1
02/01/2012
C. Mello
•Implemented support for reading and writing data in text format (Case 12558).
•Fixed a reading error with X Contacts (Case 12697).
•Implemented support for addressing devices in Broadcast mode using the N1 parameter equal to 255.
3.2.1
07/07/2010
M. Ludwig
•Implemented compatibility with Windows CE (Case 10889).
3.1.1
10/28/2009
M. Zani
•Fixed a problem when reading a single contact in a block with 16 elements (Case 10594).
3.0.1
03/16/2009
M. Zani
•Commands rewritten according to the protocol to allow blocks with more than 24 elements on a new range of values of the N2 parameter, between 1000 and 1205.
•Added new commands.
•Implemented support for a floating point data type (Case 9585).
•Implemented support for a DWord data type (Case 9474).
•Implemented support for a Long data type (Case 10073).
2.1.1
11/05/2007
A. Quites
•Enabled block writing (Case 8929).
2.0.1
12/07/2006
A. Quites
•Implemented support for TCP/IP communication and Driver ported to IOKit library (Case 3709).
•Implemented support for TCP/IP communication using an FP2 ET-LAN module (Case 5369).
•Changed the format of addresses with a Bit data type to a hexadecimal format (Case 3404).
•Implemented reading data blocks in batches (Case 6592).
•Improvements in the process of checking consistency of received data, allowing an early detection of errors.
1.0.1
01/15/2004
R. Haetinger
•All versions previous to revision control.
