Elapsed Value for Timer or Counter
Reading or Writing
N1 or B1
Address of a device in the network, between 1 (one) and 63
N2 or B2
9 (nine)
N3 or B3
Address of data
N4 or B4
Data type. Possible values are 0: Unsigned integer between 0 (zero) and 65536 or 1: Signed integer between -32767 and 32767
This Tag reads or writes 16-bit integer values referring to the current elapsed value of the timer or counter of a device in the Elapsed Value area. For Block Tags, the maximum number of Elements is 24.
