File Name
MelsecQ.dll
Manufacturer
Mitsubishi Electric Corporation
Devices
Melsec Q and L series devices with Ethernet
Protocol
Melsec communication QnA compatible 3E frame binary over Ethernet
Version
1.2.3
Last Update
02/25/2026
Platform
Win32
Dependencies
IOKit version 2.0 or later
Superblock Readings
No
Level
0
Introduction
This Driver implements the Melsec communication QnA compatible 3E frame binary over Ethernet protocol by Mitsubishi Electric Corporation, which allows Elipse Software products to communicate with Melsec Q and L series devices with Ethernet.
The Mitsubishi MelsecQ Driver was developed using Elipse Software's IOKit library. This library, after configuration, is responsible for implementing the access to a physical layer, that is, Serial, Ethernet, Modem, or RAS. For more information, please check topic Documentation of I/O Interfaces.
