Driver's Revision History
Version
Date
Author
Comments
1.2.3
02/25/2026
M. Ludwig
•Driver updated to IOKit library version 3.0 and Visual Studio 2022 (Case 37993).
1.2.2
09/06/2019
M. Ludwig
•Driver ported to Visual Studio 2017 (Case 27086).
1.2.1
01/23/2017
A. Hertzog
•Created the parameters LTS, LTC, LTN, LSTS, LSTC, LSTN, LCS, LCC, and LCN (Case 21001).
1.1.4
03/14/2016
M. Ludwig
•Fixed a false error when using a correct data type suffix in syntactical parameters (Case 20613).
1.1.3
07/08/2015
M. Ludwig
•Implemented support for the String data type (Case 18884).
1.1.2
11/14/2014
M. Ludwig
•Fixed a GPF (General Protection Failure) on Tag Browser window (Case 17773).
1.1.1
05/28/2014
M. Ludwig
•Fixed the behavior of options Network Number and PC Number on the configuration window, in which saved values were always their default values (Case 16150).
1.0.1
07/19/2014
M. Ludwig
•Initial version of this Driver.
