Configuration of Properties in Offline Mode |
The settings for this Driver's properties can also be accessed at run time, if this Driver starts in Offline mode, by using the Strings described on the next table.
Runtime configurations
Option |
Format |
Description |
Device |
MelsecA.ControlProtocolFormat |
Integer |
Defines the type of format used by the protocol. Possible values are 1: Uses Format 1 or 4: Uses Format 4 |
Special register D8120. Bit 14: Configure in 1 (one) for Dedicated Protocol and Bit 15: Configure in 0 (zero) for Format 1 or in 1 (one) for Format 4 |
MelsecA.DisableSendClear |
Boolean |
Defines whether an EOT control code is transmitted or not to clear communication after the occurrence of errors. Possible values are 0: Sending EOT is enabled or 1: Sending EOT is disabled |
MelsecA.DisableSendAckNack |
Boolean |
Defines whether ACK or NACK control codes are transmitted or not after receiving data from a device. Possible values are 0: Sending ACK or NACK is enabled or 1: Sending ACK or NACK is disabled |
MelsecA.DisableChecksum |
Boolean |
Defines whether checksum bytes are added or not to messages. Possible values are 0: Sending checksum is enabled or 1: Sending check sum disabled |
Special data register D8120. Bit 13: Configure in 0 (zero) to disable checksum or in 1 (one) to enable checksum |
MelsecA.WaitTime |
Integer |
Defines the time, in milliseconds, that a device must wait before transmitting responses. Valid values are 0 (zero), 10, 20, 30, 40, 50, 60, 70, 80, 90, 100, 110, 120, 130, 140, or 150 milliseconds |
For more information about runtime configuration, please check topic Documentation of I/O Interfaces.
