How to Connect a Melsec-FX Device to a Computer |
There are 2 (two) ways to connect an Elipse Software application to a device from FX series. The first possibility is using an RS-232 connector (FX-232ADP adapter) and the second one is using an RS-485 connector (FX-485PC-IF converter and FX-485ADP adapter). The advantage of using an RS-485 connector is the possibility of connecting to a network of devices instead of connecting to a single device.
| PC | | FX-232ADP | MELSEC-FX |
| | | | CPU |
| | RS-232 cable | | |
| RS-232 +----------------+ RS-232 | |
| connector | | connector | |
| PC |
| | | FX-485PC-IF |
| | RS-232 cable | Converter |
| RS-232 +----------------+ |
| connector | | RS232/RS485 |
RS-485 line |
| RS-485 | MELSEC-FX | | RS-485 | MELSEC-FX |
| connector | CPU | | connector | CPU |
| Station 1 | | | Station 2 | |
| FX-485ADP | | | FX-485ADP | |
