Description of Cables
RS-232 Cable
PC side                       FX-232ADP side
                              RS-232 connector
TX (2)     ------------------ RX (3)
RX (3)     ------------------ TX (2)
GROUND (7) ------------------ GROUND (7)
When RS232C cable uses pins 4 and 5
RTS (4)    ------------------ DSR (6)
CTS (5)    ------------------ DTR (20)
When RS232C cable uses pins 6 and 20
DTR (20)   ------------------ DSR (6)
DSR (6)    ------------------ DTR (20)
NOTE
These pin numbers refer to a DB-25 connector. When using a DB-9 connector, these pin numbers must be different.
RS-485 Cable
PC side                            FX-485PC-IF RS232/485 converter
TX (2)     ----------------------- RX (3)
RX (3)     ----------------------- TX (2)
RTS (4)    ----------------------- CTS (5)
CTS (5)    ----------------------- RTS (4)
GROUND (7) ----------------------- GROUND (7)
DTR (20)   ----------------------- DSR (6)
DSR (6)    ----------------------- DTR (20)
FX-485PC-IF                        FX-485ADP adapter side
RS232/485 converter                RS-485 connector
                               +-- SDA
DATA(+) -----------------------+-- RDA
GROUND --------------------------- SG (Signal Ground)
DATA(-) -----------------------+-- SDB
                               +-- RDB
