How to Connect a Melsec-A Device to a Computer
There are 2 (two) ways to connect an Elipse Software application to a device from A series. Both ways use an AJ71UC24 communication adapter. The first possibility is using an RS-232 connector and the second one is using an RS-485 connector. The advantage of using an RS-485 connector is the possibility of connecting to a network of devices instead of connecting to a single device.
RS-232
| PC        |                | AJ71UC24  | MELSEC-A  |
|           |                |           | CPU       |
|           |  RS-232 cable  |           |           |
|    RS-232 +----------------+ RS-232    |           |
| connector |                | connector |           |
                             |        R A C K        |
RS-485
| PC        |
|           |                | RS-232/   |
|           |  RS-232 cable  | RS485     |
|    RS-232 +----------------+ Adapter   |
| connector |                |           |
RS-485 line                        |
|  RS-485   | MELSEC-A  |    |  RS-485   | MELSEC-A  |
| connector | CPU       |    | connector | CPU       |
| Station 1 |           |    | Station 2 |           |
| AJ71UC24  |           |    | AJ71UC24  |           |
|        R A C K        |    |        R A C K        |
