Description of Cables
RS-232 Cable
PC side                       AJ71UC24 side
                              RS-232 connector
TX (2)     -------------------RX (3)
RX (3)     -------------------TX (2)
RTS (4)    --+--------------- CD (8)
CTS (5)    --+
DTR (20)   ------------------ DSR (6)
DSR (6)    ------------------ DTR (20)
GROUND (7) ------------------ GROUND (7)
CD (8)     ---------------+-- RTS (4)
                          +-- CTS (5)
NOTE
These pin numbers refer to a DB-25 connector. When using a DB-9 connector, these pin numbers must be different.
RS-485 Cable
PC side                            RS232/485 adapter
TX (2)     ----------------------- RX (3)
RX (3)     ----------------------- TX (2)
RTS (4)    ----------------------- CTS (5)
CTS (5)    ----------------------- RTS (4)
GROUND (7) ----------------------- GROUND (7)
RS232/485 adapter                  AJ71UC24 side
                                   RS-485 connector
                               +-- SDA
DATA(+) -----------------------+-- RDA
GROUND --------------------------- SG (Signal Ground)
DATA(-) -----------------------+-- SDB
                               +-- RDB
