Tag Reference |
This section describes how to configure Tags for Siemens ISO-on-TCP Driver to access memory areas of a device by Siemens AG. The address of each Tag is defined by the Address (Item) field using the S7 addressing syntax described in the next topics. Please check topic Data Tags to check a full description of that addressing syntax and configuration examples.
