Driver Revision History
Version
Date
Author
Comments
2.0.6
04/16/2026
M. Ludwig
•Driver updated to IOKit library version 3.0 and Visual Studio 2022 (Case 38007).
2.0.5
09/13/2019
M. Ludwig
•Driver ported to Visual Studio 2017 (Case 27159).
2.0.3
08/31/2015
F. Englert
•Driver ported to IOKit library version 2.0.
2.0.1
05/21/2015
F. Englert
•Fixed a problem when sending passwords with more than 6 (six) characters, whether using the configuration window or using the ION.UserPwd parameter.
1.9.1
06/28/2012
A. Quites
•Fixed the description of the Master Address option on the User's Manual (Case 13082).
•This Driver is now protected with and identifier for smart metering applications (Case 12594).
1.8.1
06/16/2010
A. Quites
•Documentation translated to Brazilian Portuguese and added examples in VBScript (Case 10503).
•Fixed an error when receiving frames out of order, which generated intervals without data on mass memory reading (Case 11167).
1.7.1
12/10/2008
M. Salvador
•Added an option for alphanumerical passwords (Case 8109).
•Logs are now generated with more details (Cases 8009 and 8020).
•Driver ported to the most recent version of IOKit library (Case 7557).
1.6.1
02/06/2004
M. Salvador
•Added support for communication with multiple waveforms.
1.5.1
12/11/2003
M. Salvador
•Added new Tags with the N2 parameter equal to 10 and 11, for waveforms.
•Added an option to discard duplicated FF bytes for use in noisy communication channels, usually serial links.
1.3.1
10/06/2003
M. Salvador
•This Driver now rejects packets with a source address equal to this Driver's address, that is, packets generated by echoes of packets sent by itself (Case 2647).
1.2.1
09/30/2003
F. Englert
•Added support for addresses of meters between 0 (zero) and 65535. Previous versions only supported meters between 0 (zero) and 255 (Case 2633).
1.0.1
12/17/2002
F. Englert
•Initial version of this Driver ported to IOKit library.
