<< Click to Display Table of Contents >> IO.Ethernet.PingEnable |
Configure to True to enable sending a ping command to the IP address of a remote device, before trying to connect to the socket. This socket's connection time-out cannot be controlled, therefore sending a ping command before connecting is a fast way to detect if the connection is going to fail. Configure to False to disable a ping command.
