<< Click to Display Table of Contents >> Configuration Dialog Box |
The I/O Interfaces dialog box allows configuring the I/O connection used by a Driver. This dialog box contains the Setup, Serial, Ethernet, Modem, and RAS tabs, described on the next topics. If a Driver does not implement a specific I/O connection, its corresponding tab is not available for configuration. Some Drivers may contain additional tabs, specific for each Driver, on the configuration dialog box.
