Time Zone |
This Driver assumes that the time zone of the Stations to which it communicates is the same as the computer where it is executing. Timestamps sent by this Driver are always expressed in the local time of this Driver, and not in UTC (Coordinated Universal Time) format. This Driver assumes that received timestamps are all expressed in the local time of the Stations, and not in UTC format.
