Offline Configuration
In situations in which users must configure this Driver at run time, this Driver can be set to Offline mode and change the following parameters:
•Individually: Declare a Tag with the ParamItem property containing the name of the property to change, without quotation marks, and write the new value of the property to this Tag
•Together: Use the Set Configuration Parameters Tag of IOKit library, that is, the B1 parameter equal to -1 (minus one), the B2 parameter equal to 0 (zero), the B3 parameter equal to 0 (zero), and the B4 parameter equal to 3 (three), and write to this Block Tag an array in which each 2 (two) Elements contains the name of a property and its respective value
