Stations |
In protocols in which this Driver is in Master mode, a Station represents a Slave with which this Driver communicates. In protocols in which this Driver is in Slave mode, a Station represents a logical device server by this Driver, with which an external Master communicates.
Stations must be declared on this Driver's properties window, in the Fixed Station List property on the Properties tab.
If this option is not defined, this Driver operates in automatic mode, creating Stations with default parameters as they are needed. This automatic mode is discouraged for protocols in Slave mode, because incorrect Stations can be created according to requests performed by a Master.
