Properties Window |
The Properties Window of this Driver is composed of several tabs. The tab that configures the protocol itself is the Properties tab. The Setup, Serial, Ethernet, Modem, and RAS tabs configure logs and the I/O layer of this Driver. For more information about those tabs, please check topic Documentation of I/O Interfaces.
