P Parameters
P Parameters
The P1 parameter indicates the number of offset hours to consider during syncing. This value can be positive or negative, and in this case it is converted to a Word data type, according to the next examples.
•P1 equal to 1 (one): An offset of 1 (one) hour
•P1 equal to 65534: An offset of -2 (minus two) hours
All other parameters are not used. All settings are performed on this Driver's properties window.
