Network Traffic Sniffer Library
The behavior of the PRP service offered with this Driver is based on capturing packets from the virtual adapter and transferred to physical adapters A and B. Likewise, packets received on physical adapters A or B are transferred back to that virtual adapter.
To perform a capture and injection of packets on adapters, install the Npcap network traffic sniffer library, which is installed with Wireshark or can be downloaded directly on Nmap project.
To work correctly, install the Npcap library in compatibility mode with the WinPcap API (Application Programming Interface), which can be activated on the installation window of this library.
