Filename
IEC61850.dll
Manufacturer
International Electrotechnical Commission
Devices
Servers (IEDs) compatible with IEC 61850 Standard (ED1 and ED2)
Protocol
IEC 61850 MMS over Ethernet TCP/IP
Version
3.0.58
Last Update
15/06/2026
Platform
Win32
Dependencies
IOKit version 2.0
Superblock Readings
No
Level
31298 (31201 with an Elipse Power license)
Introduction
The IEC 61850 (25 Connections) Driver communicates with protection relays and other devices using the IEC61850 protocol over Ethernet TCP/IP (MMS). This Driver allows:
•Communication with several devices on the same Driver
•Importing Tags from devices or via configuration files in SCL format
•Support for messages without confirmation of Reports, Buffered or Unbuffered
•Polling of variables not belonging to Reports
•Support for quality and timestamp information with a precision of 1 (one) millisecond
•Collecting oscillography files in COMTRADE format
Please check the next documents, provided with this manual, for more information about this Driver's functionality:
•Elipse IEC 61850 Client Driver PIXIT Ed2.pdf
•Elipse IEC 61850 Client Driver TICS Ed2.pdf
•Elipse IEC 61850 Client Driver PICS Ed2.pdf
•Elipse IEC 61850 Client Driver MICS Ed2.pdf
