Monitoring and Statistics
Starting information, such as configuration errors, are registered by the service in a file called ElipsePRPSvc.log generated on the same folder of the service, if this option is enabled.
After starting, and if the monitoring service is enabled, the service sends logs and statistics to the selected UDP port, which are received by this Driver.
Log messages are redirected to this Driver's log with a prefix "PRPService: XXXXXXXX".
Statistical messages are available in the Tags shown on the next figure, which can be created in the application.
Statistical Tags
Statistical Tags
The available Tags are described on the next table.
Tags available for statistics
Name
Description
Device
Item
LANA_Active
Indicates whether the PRP service is logically active on LAN A network adapter. Inverted network adapters, for example, do not allow any of these network adapters to remain active
ElipseClientInfo
PRPStat_LANA_Active
LANB_Active
Indicates whether the PRP service is logically active on LAN B network adapter. Inverted network adapters, for example, do not allow any of these network adapters to remain active
ElipseClientInfo
PRPStat_LANB_Active
LANA_TotalSent
Indicates the total number of packets sent by the LAN A network adapter
ElipseClientInfo
PRPStat_LANA_TotalSent
LANB_TotalSent
Indicates the total number of packets sent by the LAN B network adapter
ElipseClientInfo
PRPStat_LANB_TotalSent
LANA_TotalReceived
Indicates the total number of packets received by the LAN A network adapter
ElipseClientInfo
PRPStat_LANA_TotalReceived
LANB_TotalReceived
Indicates the total number of packets received by the LAN B network adapter
ElipseClientInfo
PRPStat_LANB_TotalReceived
Define a reasonable scan interval for these Tags, to avoid polluting this Driver's log. As a suggestion, a reasonable value can be between 5000 and 10000 ms, that is, between 5 (five) and 10 seconds.
