IEC61850 General Tab |
Allows defining all other behaviors of this Driver.
IEC61850 General tab
Available options on the IEC61850 General tab
Option |
Description |
Defines the transport layer between the default MMS (IEC 61850-8-1) and XMPP (IEC 61850-8-2) |
App Category |
To send commands, this Driver uses information from this option to fill the OrCat (Origin Category) property, which specifies the type of application sending a command, for security reasons or for solving conflicts of commands. The available values are Bay, Station, Remote, or Maintenance |
Msg Timeout (ms) |
Time to wait for a response of a command or a full message, which can be formed by several intermediate messages. The time to wait for each byte or intermediate message is defined on the Setup tab. For more information, please check topic Documentation of I/O Interfaces |
Status Check (ms) |
Time interval to send status messages, which must be answered by an IED. If there is no response, connection health can be checked, forcing a disconnection and reconnection of an IED. The value of this option must be greater than the value of the Msg Timeout (ms) option and less than the disconnection interval configured on the Setup tab. For more information, please check topic Documentation of I/O Interfaces |
Local P Selector |
Selection value for this Driver, used by the OSI presentation layer (ISO/IEC 8823) |
Local S Selector |
Selection value for this Driver, used by the OSI session layer (ISO/IEC 8327) |
Local T Selector |
Selection value for this Driver, used by the OSI transportation layer (ISO/IEC 8073) |
Local App ID Local Application Process Identification |
Identifier used by the OSI link layer (ISO/OSI 8650), in ASN.1 (Abstract Syntax Notation 1) format. Indicates a data format adopted by the AARQ (Association Request) function. Its value is usually 1,1,999,1,1 (iso.1.999.1.1) |
LD File Path |
Default directory where this Driver stores descriptive files for each Logical Device found, to improve the initialization process. In the next initialization, if a file is found on the specified directory, whose name is given by the format SERVER_LDNAME.LD, where SERVER is the name of the device and LDNAME is the name of the Logical Device, then this LD is described based on this file. This Driver provides several ways to detect changes on the database of an IED, to update these files |
Check Nameplate Mismatches |
Enables checking identification parameters of an IED (nameplate) when starting communication, to compare whether there were any changes. If true, a cache update, or rebuilding LD files, is performed |
Invert stVal BitString |
Interpretation of bitstrings with two or more bits can be changed by this option, by changing the meaning of Open or Closed statuses in an application. Default behavior is reached by deselecting this option |
Full Log Details |
Enables inserting in this Driver's log, enabled on the Setup tab, detailed information about the notification of events for any Tag. For more information, please check topic Documentation of I/O Interfaces |
Apply Local Offset to Timestamps |
Timestamps adopted by the IEC 61850 standard always refer to UTC (Coordinated Universal Time) standard. By using this option, users indicate that this Driver must apply a local offset, that is, timezone and daylight saving time, to the timestamp sent by a device |
No LD Database Scan |
Informs that no Logical Device or Logical Node request must be processed for IEDs. This option can be used when this Driver is used only to transfer files |
Block LD Cache Delete |
If the initialization process is incomplete, or when any inconsistency is detected between cache files (LD) and the current database of an IED or Server, this Driver deletes and updates cache files. Enable this option to block file removal |
Local AE Qual - Local Application Entity Qualifier |
Identifier used by the link layer as a formatter. Its value is usually 12 |
RFC 1006 Source TSAP |
This Driver uses RFC 1006 specification as a way to transport ISO packets over TCP. To do so, users must inform the TSAP (Transport Service Access Point) used to establish a connection using this protocol. Default value is 1 (one) |
Proposed MMS PDU Size |
When the Transport Layer option is configured as MMS, this option defines the size of the PDU negotiated with the server. The default value of this option is 65000 bytes |
