PLC Tag for Sending Frames |
N1 |
1 (one) |
N2 |
0 (zero) |
N3 |
0 (zero) |
N4 |
0 (zero) |
Sends a frame. Any writing to this Tag assembles the frame specified in the Item parameter using data from the Elements of the Block Tag for Sending or Receiving that contains the same Item parameter. In case of having more than one valid message format in the frame that includes all inserted data, the larger valid message is sent.
NOTE |
Reading this Tag only updates the quality, indicating whether sending the frame was successful or not. |
