Supported Objects
Supported Objects
The next table describes all object supported by DNP Mirror Master & Slave Driver.
Objects supported by DNP Mirror Master & Slave Driver
Object Code
Type
Variation
Object Name
Function
1
Static
1 (one)
Binary Input without Status
1 (one)
1
Static
2 (two)
Binary Input with Status
1 (one)
2
Event
1 (one)
Binary Input Change without Time
1 (one)
2
Event
2 (two)
Binary Input Change with Time
1 (one)
2
Event
3 (three)
Binary Input Change with Relative Time
1 (one)
3
Static
1 (one)
Double bit binary Input without Status
1 (one)
3
Static
2 (two)
Double bit binary Input with Status
1 (one)
4
Event
1 (one)
Double bit binary Input Change without Time
1 (one)
4
Event
2 (two)
Double bit binary Input Change with Time
1 (one)
10
Static
1 (one)
Binary Output
1 (one)
10
Static
2 (two)
Binary Output Status
1 (one)
11
Event
1 (one)
Binary Output Event without Time
1 (one)
11
Event
2 (two)
Binary Output Event with Time
1 (one)
12
1 (one)
Control Relay Output Block
3 (three), 4 (four), 5 (five), and 6 (six)
20
Static
1 (one)
32-bit Counter
1 (one)
20
Static
2 (two)
16-bit Binary Counter
1 (one)
20
Static
3 (three)
32-bit Delta Counter
1 (one)
20
Static
4 (four)
16-bit Delta Counter
1 (one)
20
Static
5 (five)
32-bit Counter without Flag
1 (one)
20
Static
6 (six)
16-bit  Counter without Flag
1 (one)
20
Static
7 (seven)
32-bit Delta Counter without Flag
1 (one)
20
Static
8 (eight)
16-bit  Delta Counter without Flag
1 (one)
21
Static
1 (one)
32-bit Frozen Counter
1 (one)
21
Static
2 (two)
16-bit Frozen Counter
1 (one)
21
Static
3 (three)
32-bit Frozen Delta Counter
1 (one)
21
Static
4 (four)
16-bit Frozen Delta Counter
1 (one)
21
Static
5 (five)
32-bit Frozen Counter with Time Of Freeze
1 (one)
21
Static
6 (six)
16-bit Frozen Counter with Time Of Freeze
1 (one)
21
Static
7 (seven)
32-bit Frozen Delta Counter with Time Of Freeze
1 (one)
21
Static
8 (eight)
16-bit Frozen Delta Counter with Time Of Freeze
1 (one)
21
Static
9 (nine)
32-bit Frozen Counter without Flag
1 (one)
21
Static
10
16-bit Frozen Counter without Flag
1 (one)
21
Static
11
32-bit Frozen Delta Counter without Flag
1 (one)
21
Static
12
16-bit Frozen Delta Counter without Flag
1 (one)
22
Event
1 (one)
32-bit Counter Change Event without Time
1 (one)
22
Event
2 (two)
16-bit Counter Change Event without Time
1 (one)
22
Event
3 (three)
32-bit Delta Counter Change Event without Time
1 (one)
22
Event
4 (four)
16-bit Delta Counter Change Event without Time
1 (one)
22
Event
5 (five)
32-bit Counter Change Event with Time
1 (one)
22
Event
6 (six)
16-bit Counter Change Event with Time
1 (one)
22
Event
7 (seven)
32-bit Delta Counter Change Event with Time
1 (one)
22
Event
8 (eight)
16-bit Delta Counter Change Event with Time
1 (one)
23
Event
1 (one)
1 (one)
23
Event
2 (two)
16-bit Frozen Counter Event without Time
1 (one)
23
Event
3 (three)
32-bit Frozen Delta Counter Event without Time
1 (one)
23
Event
4 (four)
16-bit Frozen Delta Counter without Time
1 (one)
23
Event
5 (five)
32-bit Frozen Counter Event with Time
1 (one)
23
Event
6 (six)
16-bit Frozen Counter Event with Time
1 (one)
23
Event
7 (seven)
32-bit Frozen Delta Counter Event with Time
1 (one)
23
Event
8 (eight)
16-bit Frozen Delta Counter Event with Time
1 (one)
30
Static
1 (one)
32-bit Analog Input
1 (one)
30
Static
2 (two)
16-bit Analog Input
1 (one)
30
Static
3 (three)
32-bit Analog Input without Flag
1 (one)
30
Static
4 (four)
16-bit Analog Input without Flag
1 (one)
30
Static
5 (five)
32-bit Analog Input Floating Point
1 (one)
31
Static
1 (one)
32-bit Frozen Analog Input
1 (one)
31
Static
2 (two)
16-bit Frozen Analog Input
1 (one)
31
Static
3 (three)
32-bit Frozen Analog Input with Time Of Freeze
1 (one)
31
Static
4 (four)
16-bit Frozen Analog Input with Time Of Freeze
1 (one)
31
Static
5 (five)
32-bit Frozen Analog Input without Flag
1 (one)
31
Static
6 (six)
16-bit Frozen Analog Input without Flag
1 (one)
31
Static
7 (seven)
32-bit Frozen Analog Input Floating Point
1 (one)
32
Event
1 (one)
32-bit Change Event without Time
1 (one)
32
Event
2 (two)
16-bit Change Event without Time
1 (one)
32
Event
3 (three)
32-bit Analog Change with Time
1 (one)
32
Event
4 (four)
16-bit Analog Change Event with Time
1 (one)
32
Event
5 (five)
32-bit Analog Change Floating Point without Time
1 (one)
32
Event
7 (seven)
32-bit Analog Change Floating Point with Time
1 (one)
33
Event
1 (one)
32-bit Frozen Analog Event without Time
1 (one)
33
Event
2 (two)
16-bit Frozen Analog Event without Time
1 (one)
33
Event
3 (three)
32-bit Frozen Analog Event with Time
1 (one)
33
Event
4 (four)
16-bit Frozen Analog Event with Time
1 (one)
33
Event
5 (five)
32-bit Frozen Analog Floating Point without Time
1 (one)
33
Event
7 (seven)
32-bit Frozen Analog Floating Point with Time
1 (one)
34
Static
1 (one)
16-bit Analog Input Dead band
1 (one)
34
Static
2 (two)
32-bit Analog Input Dead band
1 (one)
34
Static
3 (three)
32-bit Analog Input Floating Point Dead band
1 (one)
40
Static
1 (one)
32-bit Analog Output Status
1 (one)
40
Static
2 (two)
16-bit Analog Output Status
1 (one)
40
Static
3 (three)
32-bit Analog Output Status Floating Point
1 (one)
41
1 (one)
32-bit Analog Output Block
2 (two), 3 (three), 4 (four), 5 (five), and 6 (six)
41
2 (two)
16-bit Analog Output Block
41
3 (three)
32-bit Floating Point Analog Output Block
42
Event
1 (one)
32-bit Analog Output Event without Time
1 (one)
42
Event
2 (two)
16-bit Analog Output Event without Time
1 (one)
42
Event
3 (three)
32-bit Analog Output Event with Time
1 (one)
42
Event
4 (four)
16-bit Analog Output Event with Time
1 (one)
42
Event
5 (five)
32-bit Floating Point Analog Output Event without Time
1 (one)
42
Event
7 (seven)
32-bit Floating Point Analog Output Event with Time
1 (one)
50
Static
1 (one)
Time and Date
1 (one) and 2 (two)
51
Static
1 (one)
Time and Date CTO (Common Time of Occurrence)
1 (one)
51
Static
2 (two)
Unsynchronized Time and CTO (Common Time of Occurrence)
1 (one)
52
Static
2 (two)
Time Delay Fine
1 (one)
60
Static
1 (one)
Class 0 Data
1 (one)
60
Event
2 (two)
Class 1 Data
1 (one)
60
Event
3 (three)
Class 2 Data
1 (one)
60
Event
4 (four)
Class 3 Data
1 (one)
80
1 (one)
Internal Indications
1 (one) and 2 (two)
83
Event
1 (one)
Pro
1 (one)
110
Static
X
Octet String
1 (one)
111
Event
X
Octet String Event
1 (one)
