Revision History
Revision History
Version
Date
Author
Comments
1.0.7
09-02-2025
M. Ludwig
•Driver updated to IOKit library version 3.0 and Visual Studio 2022 (Case 38038).
1.0.6
05/08/2017
F. Englert
•Performed adjustments in this Driver to use IOKit library version 2.0.84 (Case 22649).
1.0.5
02/15/2017
M. Salvador
•Created an option for manual offset, positive or negative, to add to the timestamp of events on the Slave tab (Case 21903).
1.0.4
12/02/2016
M. Salvador
•Implemented a delay of 5 (five) seconds before requesting a Class 0 (zero) after a reset notification (Case 21651).
1.0.3
07/01/2015
M. Salvador
•Implemented improvements when handling disconnection for better notifications about these situations for a Master (Case 18194).
1.0.2
10/24/2014
M. Salvador
•Initial version of this Driver.
