Driver Revision History
Version
Date
Author
Comments
1.2.3
09/02/2025
M. Ludwig
•Driver updated to IOKit library version 3.0 and Visual Studio 2022 (Case 37957).
1.2.2
04/06/2020
C. Mello
•Driver ported to IOKit library version 2.0 (Case 23418).
•Adjustments to prevent a disconnection when resizing a DDE server window (Case 12641).
•Adjustments to prevent an excessive CPU consumption with undefined data (Case 12539).
•Implemented a RemoteDDEClient application for DDE communication between system accounts, starting with Windows Vista (Case 10699).
1.1.1
12/19/2008
C. Mello
•Added an option to filter data (Case 9812).
•Added a Stop Advise Loop transaction for a Tag with the N2 parameter equal to 3 (Case 9812).
•Internal optimizations for transactions in Request mode (Case 9812).
•Adjustments to set a default Topic + Item on this Driver's configurations (Case 9699).
1.0.1
04/16/2007
C. Mello
•Initial version of this Driver.
