Configuring Properties
Before using this Driver, users must configure the options on the DDEClient tab, shown on the next figure.
DDEClient tab
DDEClient tab
The available options on this tab are described on the next table
Available options on the DDEClient tab
Option
Description
Application
Name of an application supporting DDE server functions
Use default DDE Topic + Item
If this option is enabled, this Driver uses the values of Default Topic and Default Item options when an application Tag does not inform any data for the Device and Item parameters, respectively
Query DDE Server
Use this option to query all topics available on a DDE server
Default Topic
Defines a default topic to use if an application Tag does not inform any data for the Device parameter
Default Item
Defines a default item to use if an application Tag does not inform any data for the Item parameter
Keep last data received in cache
If this option is enabled, all values in the cache memory are read, but always preserving the last value before clearing the cache memory of this Driver. If this option is not enabled, all values in the cache memory are read, and a possible lack of data may occur when that memory is completely empty, changing the quality of a PLC Tag to Bad
Cache size
Defines the maximum amount of data stacked in the cache memory of this Driver. If this option is configured with a value of 0 (zero), the cache memory has no limits for stacking data
Discard these data list
Defines all data to discard by this Driver, considering uppercase and lowercase letters to identify data
