Tag Reference
Tag Reference
All Tags follow the next pattern:
•Device property: Organization or Site
•Item property: Stream
This Driver offers a Tag Browser functionality, which allows listing Organizations, Sites and Streams found on a server, on the Tags available from driver list and that can be dragged to the Tags from current project list.
Organizations are groups of Sites, and Sites correspond to the name of a location where a Schneider Data Logger 4G LTE IoT device is installed. In this Driver, Sites that do not belong to an Organization are placed in a fictional Organization called "NoOrg" to keep the pattern of addressing. Inside a Site, or device, there are Streams, which can be linked to Tags. Example of a Tag address:
•Device property: MyOrg/Device1234
•Item property: Pressure
The next Tags are reserved:
•Latitude and Longitude: To receive information on latitude and longitude, inform in the Item property the values "GPSLat" and "GPSLon", respectively. These Tags are updated at the interval defined in the Site GPS Scan (s) option. The Device property must be configured the same way, that is, Organization/Site
•Connection Status with a Schneider API: Users must create a Tag with the text "APIStatus" in the Item property and the Device property must be an empty String
NOTES
•All Tags are read-only.
•Tags whose values are identified as numbers are returned as integer or Double numbers. Tags containing alphanumeric characters are returned as text.
