Revision History
Revision History
Version
Date
Author
Comments
3.0.4
02/09/2025
M. Ludwig
•Driver updated to IOKit library version 3.0 and Visual Studio 2022 (Case 38033).
2.4.1
11/23/2012
M. Salvador
•Improved performance of collecting disturbances on secondary port (Case 13017).
•Added COMTRADE status Tags (Case 13032).
•Added a protection level for power Drivers (Case 13538).
2.3.1
01/20/2010
M. Salvador
•Revision of source code.
2.2.1
12/12/2008
M. Salvador
•Fixed the generation of files in COMTRADE format, errors in date formats, and other minor adjustments.
0.4.1
12/12/2002
C. Mello
•Added the SET REAL TIME command (Case 1415).
0.3.1
10/28/2002
C. Mello
•Fixed an error in the I/O Server when starting the communication (Case 1179).
0.1.1
07/02/2002
C. Mello
•Initial version of this Driver (Case 62).
