Information about the Courier Protocol |
The Courier protocol was primarily developed for communication with digital protection relays and uses a format for transmitting asynchronous data based on the IEC 61870 protocol. Each information is stored as cells inside a relay, and they can be sent as events or using polling (cyclic interrogation).
