Changing Properties at Run Time
All properties described on the previous topic can be changed at run time using the next Strings from the IOKit library:
•Default slave address: "COURIER.DefaultSlaveAddress"
•Application Timeout (ms): "COURIER.AppTimeout"
•Poll Interval (ms): "COURIER.PollTime"
•Link Retries: "COURIER.LinkRetries"
•Slave Demotion Time (s): "COURIER.DemotionTime"
•2nd Port EvtScan (s): "Courier.SecondaryPortEvtScan"
•Max Consecutive Messages per Slave (0 to disable): "COURIER.ConsecFrames"
•General Interrogation every (s): "COURIER.GeneralInterrogation"
•Broadcast Time Synchronization every (s): "COURIER.GlobalSyncTime"
•Transfer Disturbances: "COURIER.DoDisturbance"
•Directory for Comtrade Files: "COURIER.ComtradeDir"
