File Name
Conitel2020.dll
Manufacturer
Leeds & Northrup Co.
Devices
UTR CORTEX 2000 and other devices compatible with Conitel 2020 protocol
Protocol
Conitel 2020
Version
1.0.26
Last Update
08/28/2025
Platform
Win32
Dependencies
None
Superblock Readings
No
Level
31309
Introduction
This Driver implements the Conitel 2020 communication protocol by Leeds & Northrup Co., allowing Elipse Software products to monitor systems that communicate using this protocol, using UTR CORTEX 2000 and other devices compatible with Conitel 2020 protocol.
Leeds & Northrup Conitel2020 Driver was developed using Elipse Software's IOKit library. This library, after configuration, is responsible for implementing the physical layer, Serial, Ethernet, Modem, or RAS. For more information, please check topic Documentation of I/O Interfaces.
This Driver is not compatible with Elipse SCADA, because it uses the new features of Elipse E3, Elipse Power, or Elipse Water, such as configuring Tags using Strings and returning values using callbacks, which are not available in Elipse SCADA.
