Driver Revision History
Version
Date
Author
Comments
1.0.26
08/28/2025
M. Ludwig
•Driver updated to IOKit library version 3.0 and Visual Studio 2022 (Case 37991).
1.0.25
12/21/2020
M. Ludwig
•Implemented the update of the Conitel2020.ListenMode parameter at run time (Case 24040).
1.0.20
05/15/2017
F. Englert
•Implemented the Active Master mode, with support to SOE and to send Trip, Close, and Setpoint commands.
1.0.10
11/20/2015
A. Quites
•Fixed the numbering of bits, which was inverted relative to the default of Conitel 2020 protocol. Now bit 1 (one) is always the most significant.
1.0.9
09/01/2015
A. Quites
•Initial version of this Driver.
