Driver Revision History
Version
Date
Author
Comments
3.0.7
08/25/2025
M. Ludwig
•Driver updated to IOKit library version 3.0 and Visual Studio 2022 (Case 37945).
3.0.6
11/16/2020
C. Mello
•Added options for retrieving responses not received due to time-out (Case 29286).
3.0.5
04/07/2020
C. Mello
•Final portability adjustments for IOKit library version 2.0 and Visual Studio 2017 (Case 28640).
3.0.4
09/27/2019
C. Mello
•Driver ported to Visual Studio 2017 (Case 27447).
3.0.3
09/18/2015
G. Taschetto
•Driver ported to IOKit library version 2.0 (Case 13984).
3.0.1
06/10/2013
G. Taschetto
•Fixed an error that did not allow reading or writing char values in protocol's 0x02 and 0x12 functions (Case 13963).
2.3.1
08/22/2012
G. Taschetto
•Fixed a problem when using the IO.Log.Enable Tag (Case 13120).
•Added support for defining specific settings of this Driver at run time.
2.2.1
01/14/2009
A. Quites
•Fixed a parameter error in the Tag with the B2 parameter equal to 10 (Case 9811).
2.1.1
05/26/2008
C. Mello
•Compatibility with Windows CE (Pocket ARM) (Case 9477).
2.0.1
11/10/2006
A. Quites
•Original version with IOKit library (Case 3339).
1.5.1
10/27/2003
A. Quites
•Added communication with modems (Case 1755).
1.4.1
04/25/2003
A. Quites
•Fixed a communication problem with base stations (Case 1794).
1.3.1
11/20/2002
A. Quites
•Fixed an error of not emptying the buffer before next communication (Case 1275).
1.0.1
R. Farina
•All versions previous to revision control.
