IO.TAPI.HangUp
IO.TAPI.HangUp
Type of Tag
I/O Tag
Type of Access
Write-Only
N1 Parameter
-1 (minus one)
N2 Parameter
0 (zero)
N3 Parameter
3 (three)
N4 Parameter
4 (four)
String Configuration
IO.TAPI.HangUp
Any value written to this Tag turns the current call off.
NOTE
Use this command only when managing the physical layer manually or when explicitly trying to force a Driver to restart the communication. If the physical layer is configured for automatic reconnection, the Driver immediately tries to reestablish the connection.
