IO.TAPI.ModemID
IO.TAPI.ModemID
Integer This is the identification number of a modem. This ID is created by Windows and used internally to identify a modem on a list of devices installed on a computer. This ID may not remain valid if a modem is reinstalled or an application is executed on another computer.
NOTE
It is advisable to configure this property as 0 (zero), indicating that a Driver must use the first available modem.
